I installed ArcGIS Viewer for Flex 3.0. The operational layers were from our ArcGIS Server. But the Edit widget shows "No editable layers". What should I do to make editable layers available?
If there are editable feature layers, or map services that have a matching feature service, then they should automatically display. What does the <basemaps> and <operationallayers> tags look like in your config.xml?
Are you layers coming from SDE? It is my understanding that the edit widget requres a featureservice from an SDE dataset and not a standard FGDB or shapefile.
Is there a way to store your data in SQL Server 2012 and therefore use the edit widget without the need for SDE? Has anybody had ssuccess doing this? :confused:
