private function sharedDataUpdated(event:AppEvent):void { if (event.data.key == "Board_Data") { if (event.data.collection[0]){ //mailme(); add2favs(event.data.collection[0]); } } }
AppEvent.addListener(AppEvent.DATA_SENT, sharedDataUpdated2); fetchSharedData();
AppEvent.addListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
com.esri.viewer.customskins.PopUpRendererSkin(recAC[0]);
What part of the widget would the data go???? That is up to you, and your desired workflow as the developer you would have the best knowledge of what you are attempting to do here.
