Carl, If you have the ability to change code and recompile the viewer than there is a simple fix for this.Replace the GeoRSSUtil.as code with this:////////////////////////////////////////////////////////////////////////////////
// Copyright (c) 2010-2011 Esri
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions. See use restrictions in the file:
// <install location>/License.txt
package com.esri.viewer.utils
import com.esri.ags.geometry.Geometry;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.geometry.Polygon;
import com.esri.ags.geometry.Polyline;
import mx.utils.StringUtil;
public class GeoRSSUtil
private static const GEORSS:Namespace = Namespaces.GEORSS_NS;
private static const GEO:Namespace = Namespaces.GEO_NS;
private static const GML:Namespace = Namespaces.GML_NS;
private static const GEOLL:Namespace = Namespaces.GEO_LL;
public function GeoRSSUtil(singletonEnforcer:SingletonEnforcer)
public static function toGeometry(x:XML):Geometry
var georssPoint:String = String(x.GEORSS::point);
if (georssPoint)
return parseGeoRSSPoint(georssPoint);
var georssLine:String = String(x.GEORSS::line);
if (georssLine)
return parseGeoRSSLine(georssLine);
var georssPolygon:String = String(x.GEORSS::polygon);
if (georssPolygon)
return parseGeoRSSPolygon(georssPolygon);
var pointList:XMLList = x.GEO::point;
if (pointList && pointList.length() > 0)
var geoPoint:XML = pointList[0];
var getLat:Number = Number(geoPoint.GEO::lat);
var geoLon:Number = Number(geoPoint.GEO::long);
return new MapPoint(geoLon, getLat);
//My Add
var markerPoint:String = String(x.marker);
if (markerPoint)
return parseGeoRSSPoint(markerPoint);
//End My Add
var whereList:XMLList = x.GEORSS::where;
if (whereList && whereList.length() > 0)
var pos:String = whereList[0].GML::Point[0].GML::pos[0];
var arr:Array = pos.split(" ");
var gmlLat:Number = Number(arr[0]);
var gmlLon:Number = Number(arr[1]);
return new MapPoint(gmlLon, gmlLat);
var georssLat:String = String(x.GEOLL::lat);
var georssLong:Number = Number(x.GEOLL::long);
if ((georssLong) && (georssLat))
return new MapPoint(Number(georssLong), Number(georssLat));
return null;
private static function parseGeoRSSWhere(x:XML):Geometry
return null;
private static function parseGeoRSSPoint(text:String):Geometry
var tokens:Array = StringUtil.trim(text).split(" ");
var lat:Number = Number(tokens[0]);
var lon:Number = Number(tokens[1]);
return new MapPoint(lon, lat);
private static function parseGeoRSSLine(text:String):Geometry
var path:Array = [];
if (tokens.length > 3)
for (var i:int = 0, j:int = 1; j < tokens.length; i += 2, j += 2)
var lat:Number = Number(tokens);
var lon:Number = Number(tokens);
path.push(new MapPoint(lon, lat));
return new Polyline([ path ]);
private static function parseGeoRSSPolygon(text:String):Geometry
return new Polygon([ path ]);
class SingletonEnforcer
