Hi, i need to change de presentation of the Edit PopUp. There is a way to show the edit popup (with the editable fields) separated from the map?
2201
09-04-2015 06:37 AM
RafaelTietz_Strellow
I have a ArcgisDynamicService who is editable in an application esri viewer for Flex on Web.
But my Layer has to many fields to be edited, so the popup always is presented wrong, and the edit is unpleasant.
There is a way to create other infoWindow or content, with contains the same properties of the AttributeInspector, but is fixed, separated from the selected feature on map?
All this in the code?
Thank you.
