HTML / Text box Widget
528
06-17-2014 06:25 AM
MicahWilliamson
Occasional Contributor II
I'm looking for something that seems would already be available:
A simple widget that opens a pre-determined HTML or text box.
I'm NOT talking the 'About' splash screen.
Essentially i am 'taking away' the ID tool from the Header in leu of pop-ups and i want to inform the user that the tool is no longer
needed and just click on a feature.
i know i could just remove it. but i will get calls. If i could leave the ID button there and just have a simple text box pop up informing
the user to just click on a feature instead i anticipate removing the button in a few months. It's about change mitigation.
With the amazing user base that we have for the flex viewer, i assume this tool is already created somewhere or it's rolled into basic
functionality. What am i missing?
VenusScott
Occasional Contributor III
Would the "links" widget in the Layout tab be what you are referencing?
AnthonyGiles
Micah,
You could use the splash widget but reference it as you would a normal widget not by using the <splashpage> tag.
Regards
Anthony
MicahWilliamson
Great idea. It works well the first time and I can even add more HTML in the .XML file. However after trying to close the box and subsequent clicking on the widget button, there seems to be a problem and the 'highlighted line' underneath the widget button never quite goes away. See Screenshot: http://screencast.com/t/C9UTutFtrq
So it only works once.
