Lock/Constrain Extents Flexviewer 3.1
2750
6
01-15-2013 05:44 AM
MarkHanway1
I am using the latest 3.1 viewer and looking to secure the extent.   Disabling the left mouse function would be nice but I would like to constrain the extent similar to http://thunderhead.esri.com/readonlyurl/ExtentApp.html
Here is the full blogpost:
http://thunderheadxpler.blogspot.com/2009/01/constraining-map-extent.html
I know Robert Scheitlin expanded the example from Mansour Raad for an early version of the viewer in this post http://forums.esri.com/Thread.asp?c=158&f=2421&t=295234&mc=0
There are 2 files:
ConstrainedMap.as
MapManager.mxml
I haven't been successful getting this updated for 3.1 and was wondering if anyone has migrated the action script an updated changes to the mapmanager.mxml for the later versions of the viewer?
Mark
MatthewGoulet1
New Contributor III
Has anyone gotten the zoom in/out functionality to work with Mansour's/Robert's constraint code? Panning seems fine (I'm using Viewer 3.2), but whenever I zoom in or out, the map goes to it's full extent and "shakes" up and down.
Is the only solution to prevent zooming?
RobertScheitlin__GISP
Mark,
   Here is a more recent version for Flex Viewer 2.2 it may be easier to port over.
http://forums.arcgis.com/threads/20799-Restrict-View-Port-Bounds-in-Flex-Viewer-2.x?p=67595&viewfull...
I will see if I can find the time to do it for 3.1, but no promises.
RhettZufelt
MVP Frequent Contributor
Hi Robert,
I tried to incorporate this, and it seems that most ports fine.  However, it does not like the
m_initialScale = ProjUtils.convertExtentToScale(m_cExtent, width, height, Units.esri_internal::esriMeters);
and it gives me the following:
-1137: Incorrect number of arguments. Expected no more than 3.
-1119: Access of possibly undefined property esriMeters through a reference with static type Class.
-height
Looked through the api and don't see the that class in utils anymore, yet the autocomplete has it, but only wants 3 args.
Anyway, I'll keep looking try to figure it out, but thought I'd let you know that most of it comes across.
R_
MarkHanway1
Hi Rhett,
Did you have any trouble with Line 41?  const newScale:Number = ProjUtils.convertExtentToScale(value, width, height, Units.esri_internal::UNITS_METERS);
I had similar issues with line 41 and line 69 "Access of possibly undefined property esri_internal through a reference with static type Class"
RhettZufelt
Yep, both of them.  Still can't figure out how to convert an extent to scale now.
R_
MatthewGoulet1
New Contributor III
NancyGnanicys
New Contributor II
I just downloaded the code provided at the site :
http://forums.esri.com/Thread.asp?c=158&f=2421&t=293364
However, I do not have a mapmanager.xml anywhere when I open the application folder.  Where do I put the MapManager.mxml or constrainedmap.as?  I'm using flex viewer 3.2 and not flash builder.  What do I do with this to get my map to constrain and "bounce" back in my application?
