Mayday Mayday...  Edit Widget 3.6 remove info popup, use attribute inspector outside map instead
3795
02-20-2015 03:31 PM
MegPeterson
New Contributor III
Hi all -
I'm stuck.
I'm creating an editing site using the Flex Viewer 3.6. When users create a new feature, instead of entering the info via the pop up window that covers the map, is it possible to have them enter the attributes using the attribute inspector outside the map? My users want to be able to fully see all the shapes on the map, and the pop up is blocking the view.
Would appreciate any and all help! Thank you.
