using flexview 3.0 final uncompiled.
I am using the popups to identify a polygon layer that I have loaded with visible="true" alpha="0.0"
This allows me to have the layer loaded so I can identify it with the popup, but is not visible. However, when you click on a polygon, it highlights the perimeter of the selected polygon and shows the popup window with the information.
Is there a way to have it also change the fill color of the selected polygon? Or, have it temporarily set the alpha="1.0" for the currently selected polygon, and remove it once the popup selection is cleared or changed?
Basically, I don't want all the polys visible most the time, only the currently selected one, but want it to be obvious what "area" we are identifying (the outline doesn't quite do it when the polys are larger than the display extent).
Thanks for any direction,
R_
