Has anyone else had any problems with the view extent not going to the geocoded item after running the search? I am not using the default projection, I have set my config file to match my data wkid="2243" .
After running the search it takes me to a blank view, way out of my extent, probably trying to set the view extent based upon wgs84 values? The interesting thing is that if I use the zoom to extents, to get me back to my map, I can generally see the geocoded point labeled correctly on the map. i.e. geocode respects my projection, extents do not not appear to.
Ideas?
Thank you
