Justin,
I think it is going to have something to do with your zoom code and timing issues. Post the code that you are using in the MapLoadComplete.
Think your right. I read a couple of other posts in more detail and moved the code (the exact same code) into the layerloadComplete event and it now works. Here is the code snippet. if (ExternalInterface.available)
var result:URLVariables = new URLVariables();
var urlSubstring:String = ExternalInterface.call("window.location.search.substring", 1);
if (urlSubstring && urlSubstring.length > 0 != "debug=true")
result.decode(urlSubstring);
// Parse URL
var qValue:String
if (result["excavationpermit"])
qValue = result["excavationpermit"];
var queryTask:QueryTask = new QueryTask();
var query:Query = new Query();
query.returnGeometry = true;
query.where = "order_no = '" + qValue + "'";
queryTask.url = "http://df21pce00255325/ArcGIS/rest/services/Common_Utilities/FeatureServer/0";
queryTask.execute(query, new AsyncResponder(onResult, onFault));
function onResult(featureSet:FeatureSet, token:Object = null):void
if (featureSet.features.length == 0)
Alert.show("Excavation Permit Not Found. Please Try Again.");
else
//uninon the sel graphic extents and zoom
var unionExtent:Extent;
var myFirstGraphic:Graphic = featureSet.features[0];
unionExtent = Polygon(myFirstGraphic.geometry).extent;
for each (var myGraphic1:Graphic in featureSet.features)
unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent);
map.extent = unionExtent; // Zoom to queried polygon
map.scale = 250;
// make sure the whole extent is visible
if (!map.extent.contains(unionExtent))
map.level--;
//turn on required layers
var layers:ArrayCollection = map.layers as ArrayCollection;
for each (var layer:Layer in layers)
if (layer.name.toLowerCase() == "imagery")
layer.visible = false;
else
layer.visible = true;
function onFault(info:Object, token:Object = null):void {
