PopUp 2.3 - Add a hyperlink to outside url based on identified feature
1058
9
05-02-2011 07:39 AM
PaulMcBride
What I am wanting to do is bind a attribute from the identified feature to the end of a url.  I have a parcel database that has a State_PIN field which needs placed on the end of this...
"http://www.go2gov.net/madison/tax/showPropertyInfo.do?account="
Any suggestions?
AlexSanders
Paul,
Are you using Robert's Identify Widget?  If so insert the URL in the <linkprefix> area then put the field that contains the number you want to pass in the <linkfield> area.  Attached is the code from one of our Identify.xml pages
PaulMcBride
I'm actually trying to do all of this within the popup window.  I will use his identify widget until I get this figured out though.  Thanks for the information!
GeraldLee__GISP
im wanting to do this inside a popup as well. did you ever have any luck?
KC
Does this work for  you?
<?xml version="1.0" ?>
<configuration>
    <title>{APN}</title>
    <description>
        <![CDATA[<a href="http://www.go2gov.net/madison/tax/showPropertyInfo.do?account={STATE_PIN}">View Property</a>]]>
    </description>
    <fields>
        <field name="APN"/>
 <field name="STATE_PIN"/>
    </fields>
</configuration>
HalilSiddique
Occasional Contributor II
<configuration>
    <description>
    </description>
    <fields>
        <field name="APN"/>
    </fields>
</configuration>
I've tried the above and got it to work, but now it only shows the URL not any fields from the fields tag.
Anyone else had this problem? or know how to fix this?
Cheers
Halil
RobertScheitlin__GISP
Halil,
   You can't use the description and have the fields display as well it is one or the other.
HalilSiddique
Ok.
Damn:(
RichardDiaz
Try this out:
<configuration>
    <description>
        <![CDATA[<a href="http://www.go2gov.net/madison/tax/showPropertyInfo.do?account={STATE_PIN}">View Property</a><br>    <li>APN: {APN}</li><li>STATE_PIN: {STATE_PIN}</li>]]>
    </description>
</configuration>
See this link for more information on the htmlText property in Flex.
DanielMunoz
Thank you!
This works very well
