Terry,
Once you have made the popup changes discussed earlier than you go to the Project menu and choose "Export release build" and that will create bin-release folder with all the compiled code can the contents of that folder is what you copy over to the web server.
Thanks I am feeling so much better about this - you have been so kind to provide me with detailed guidance. In reading the posts again it appears the file I need to make the change to however is the PopUpMediaBrowser. I tried applying the same logic you have guided me through but substituting MyPopUpMediaBrowser in place of the MyPopUpRendererSkin without success.
I am having difficulties with locating the Host component.
I managed somehow to get a copy of the PopUpMediaBrowserSkin.mxml into my project and so I moved it to the supportClasses folder.
I attempted to add it to the defaults.css however that produced a warning the
"Cannot resolve namespace qualified type "PopUpMediaBrowser' in CSS selector . . ."
I attempted to remove the code I added, resave the file but I'm still getting these warnings even thought the code it is referencing is not in my project?
I did a clean on the project and it appears that warning has cleared but I'm back to not having the PopUpMediaBroswer added to the css file. When I enter in the esri| and attempt to browse to the PopUpMediaBrowser it is not an option to select.
I'm thinking I need to add a name space but not clear if that is correct or not. Still learning.
Terry,
I think that is normal as the Flex API is NOT open source.
Terry,
It is pretty hard for me to know where things have went wrong for you. The only thing I can do is suggest you review each step and see if you missed something. You need to keep in mind that flex is a CaSe sensitive language so if your paths are off even by the case of one letter, that is no good.
Thanks Robert - I do realize the importance of case and will go back through every step and try to identify my mistakes. Thanks for all your assistance in this.
Terry,
For removing the border from the image you need to foloow this thread:
http://forums.arcgis.com/threads/38375-Change-media-container-size-in-Pop-Up-Window
