Terry,
What is your PopUpMediaBrowserSkin.mxml called and where did you place it? Your MyPopUpRenderSkin.mxml needs to point to your PopUpMediaBrowserSkin.mxml using the skinClass attribute.
I also added the import in the fx Script blockYou can undue that.
import com.esri.viewer.skins.supporClasses.MyPopUpMediaBrowserSkin;
And in the default.css I enteredYou can undue that as well as they way the component knows to use your customized skin is through you setting the skinClass attribute.
esri|PopUpMediaBrowser
skinClass:ClassReference("com.esri.viewer.skins.supportClasses.MyPopUpMediaBrowser");
<supportClasses:PopUpMediaBrowser id="mediaBrowser"
height="270"
width="100%"
skinClass="com.esri.viewer.skins.supportClasses.MyPopUpMediaBrowser"/>
height="270"
width="100%"
skinClass="com.esri.viewer.skins.supportClasses.MyPopUpMediaBrowserSkin"/>
Terry,
Hmm... You can undue that.
You are not replacing the actual PopUpMediaBrowser component. You are just updating the skinClass.
It looks like your issue is actually in this code:<supportClasses:PopUpMediaBrowser id="mediaBrowser" height="270" width="100%" skinClass="com.esri.viewer.skins.supportClasses.MyPopUpMediaBrowser"/>
that should be:<supportClasses:PopUpMediaBrowser id="mediaBrowser" height="270" width="100%" skinClass="com.esri.viewer.skins.supportClasses.MyPopUpMediaBrowserSkin"/>
Terry,
I am not real sure where you are going wrong then. I have done these steps (even naming my "MyPopupRendererSkin.mxml" just like yours) and I have no problem seeing the changes, to include the rectangle being removed. Here is my whole MyPopUpMediaBrowserSkin.mxml
