Amy,
It might be possible but I can not say. I have never tried to downgrade a widget. Why are you still on a version of the viewer that is six minor releases behind?
Amy,
I just tested again and it works fine for me once I enter my credentials... What are the addresses you are attempting to route to and from?
<reversegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</reversegeocode>
Amy,
So it sounds like you are using the map click button to reverse geocode. Do you have the reversegeocode set in the xml?<reversegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</reversegeocode>
Amy,
What part of the world are you in? I am not sure why the reverse geocode is not returning state and zip if you are in the US.
Amy,
I am not sure what trouble you are having but when I click on the map in the same location I have no issue.
[ATTACH=CONFIG]31378[/ATTACH]
