Roberto,
You need to use either the computer name or the IP and not both. It sees http://163.155.89.150 and http://devn19 as different machines.
Roberto,
OK in that case than the crossdomain.xml needs to be on the ArcGIS Server machine than in it's wwwroot directory.
Robert,
I copied the crossdomain.xml file to the webroot directory in devn19 and now everything works!!!!
Thank you very much for your help.
Regards
Roberto
