Simple question: How to use the Attribute Inspector Outside the Map with the Flex Viewer
3766
02-13-2015 04:00 PM
MegPeterson
New Contributor III
Hi all - I know there's probably a simple answer somewhere but I can't find it!
I'm using the Flex Viewer 3.6 version and simply want to use the attribute inspector (via the Edit widget) outside the map. Are there any simply instructions for doing this or are all the example in the API meant for custom projects?
Many thanks, Meg
