I have an application in which there are two states - login & viewer. For editing the edit widget is used with little customization. Here is my problem - After the user logs in, the display of the editable layers is stretched (attachment shows the expected result and the stretched one). These are my observations on this issue:
First time, the application is opened it opens properly. Any subsequent instances show the editable features alone as stretched.
If the cache is cleared then again the first time the display is fine & then the problem repeats itself (the cache is set to be cleared every min)
While this happens the default scale bar does not display properly (I have replaced it with a custom scale bar to work around this)
While the application opens and the feature layer is stretched, zoom to full extent fixes the stretching although it does not fix the scale bar
If the application is changed to open directly in "viewer" state rather than the "login" state, then this issue does not occur. (Really wonder why?! till this I was guessing it as an issue of caching)
Anyone encountered such an issue? Any clues / directions is greatly appreciated.
