Thanks again Robert.I modified your CopyrightWidget.mxml a little in order to accomodate the OpenStreetMap copyright notice, and to enable linking:<?xml version="1.0" encoding="utf-8"?>
// Version 2.1 - Oct 7, 2010
// Delevoped by Robert Scheitlin
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:viewer="com.esri.viewer.*"
layout="horizontal"
widgetConfigLoaded="basewidget_widgetConfigLoadedHandler(event)">
<fx:Script>
<![CDATA[
import com.esri.ags.events.MapEvent;
import com.esri.ags.layers.*;
import com.esri.viewer.AppEvent;
import com.esri.viewer.ViewerContainer;
// Import statements added to allow links in copyright notice
import flashx.textLayout.conversion.TextConverter;
import flashx.textLayout.elements.TextFlow;
// Set the OpenStreetMap copyright notice
private var osmHtmlText:String = '© <a href="http://www.openstreetmap.org/" target="_blank">OpenStreetMap</a> contributors, '
+ '<a href="http://creativecommons.org/licenses/by-sa/2.0/" target="_blank">CC-BY-SA</a>';
private var osmTF:TextFlow = TextConverter.importToFlow(osmHtmlText, TextConverter.TEXT_FIELD_HTML_FORMAT);
protected function basewidget_widgetConfigLoadedHandler(event:Event):void
if (configXML)
const color:String = configXML.label.@color;
cright.setStyle("color", toNumber(color.length ? color : "0x000000"));
const fontFamily:String = configXML.label.@fontfamily;
cright.setStyle("fontFamily", fontFamily.length ? fontFamily : "Verdana");
const fontSize:String = configXML.label.@fontsize;
cright.setStyle("fontSize", parseInt(fontSize.length ? fontSize : "9"));
const fontWeight:String = configXML.label.@fontweight;
cright.setStyle("fontWeight", fontWeight.length ? fontWeight : "bold");
if (map.loaded)
map_loadHandler(null);
else
map.addEventListener(MapEvent.LOAD, map_loadHandler);
function map_loadHandler(event:MapEvent):void
map.removeEventListener(MapEvent.LOAD, map_loadHandler);
ViewerContainer.addEventListener(AppEvent.BASEMAP_SWITCH,basemapSwitched);
//Set the copyright text to the first basemap in the list
var configBasemaps:Array = configData.basemaps;
var label:String = configBasemaps[0].label;
var layer:Layer = map.getLayer(label);
if (layer is ArcGISTiledMapServiceLayer)
if(layer.visible)
cright.text = (layer as ArcGISTiledMapServiceLayer).copyright;
else if (layer is ArcGISDynamicMapServiceLayer)
if(layer.visible)
cright.text = (layer as ArcGISDynamicMapServiceLayer).copyright;
else if (layer is ArcGISImageServiceLayer)
if(layer.visible)
cright.text = (layer as ArcGISImageServiceLayer).copyright;
// if OpenStreetMapLayer
else if (layer is OpenStreetMapLayer)
if(layer.visible)
cright.textFlow = osmTF;
private function toNumber(value:String):int
if (value.substr(0, 2) == "0x")
return parseInt(value, 16);
return parseInt(value, 10);
protected function basemapSwitched(event:AppEvent):void
var id:String = event.data as String;
if (id)
for (var i:Number = 0; i < configBasemaps.length; i++)
var label:String = configBasemaps.label;
if(layer.visible)
if(layer.visible)
if(layer.visible)
if(layer.visible)
</fx:Script>
<viewer:filters>
<mx:GlowFilter alpha="1"
blurX="3"
blurY="3"
color="0xFFFFFF"
strength="7"/>
</viewer:filters>
<!--<s:Label id="cright"/>-->
<s:RichEditableText id="cright"
bottom="2"
editable="false"
horizontalCenter="0"
selectable="false"/>
</viewer:BaseWidget>
Karl
