AttachmentEditor with Secured data
671
07-17-2012 01:28 PM
StacieMcGahey
It seems that the AttachmentEditor in the Popup window does not work with secured data.  When you click on the attachment, it goes to a login screen, but even after a valid user id and password, it does not give access to the attachment.  Our IT people said the proxy url needs to be prepended to the rest web service url:
http://******.com/proxy/proxy2.ashx?http://******.com/FeatureServer/3/attachments/401
Is there a way to edit the URL before it gets sent to the AttachementEditor?  Or is there some other work-around?
ScottBailey
Has anyone ever fixed this or found a workaround? I have a later with attachments that uses a proxy. Everything functions correctly except for adding attachments. When not using the proxy it work fine. Please Help!
