using System; using System.Net; using System.Windows; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Ink; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Shapes; //using System.Windows.Interactivity; using System.ComponentModel.Composition; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Extensibility; using ESRI.ArcGIS.Client.Geometry; using ESRI.ArcGIS.Client.Tasks; using ESRI.ArcGIS.Client.Behaviors; using System.Windows.Threading; namespace ECFMapLoad.AddIns { [Export(typeof(Behavior<Map>))] [DisplayName("Load ECF Data")] public class MyBehavior : Behavior<Map> { #region Behavior Overrides protected override void OnAttached() { base.OnAttached(); // Show saved configuration text MapApplication.Current.Initialized += Initialized; } private void Initialized(object sender, EventArgs args) { } protected override void OnDetaching() { // Detach the event handler MapApplication.Current.Initialized -= Initialized; base.OnDetaching(); } #endregion } }
Solved! Go to Solution.
