Does anybody have a code example of how to reference the DisplayName (Alias) property for a field as defined by the application builder? Know it can be accessed through the ESRI.ArcGIS.Client.Extensibility.FieldSettings class but I don't know how to reference it in code.
I can get the alias name defined in the database but this might differ from the value set in the application builder. Also need to know if field is visible or not. I am trying to populate a combobox with only the visible fields for a table using the alias values.
Thank you
