Go to Coordinates tool
3492
05-31-2014 10:42 PM
HaniDraidi
Occasional Contributor II
When I add ???Go to Coordinates??? tool, the following error appears.
Method not found: 'Void ESRI.ArcGIS.Client.Extensibility.MapApplication.ShowWindow(System.String, System.Windows.FrameworkElement, Boolean, System.EventHandler`1<System.ComponentModel.CancelEventArgs>, System.EventHandler, ESRI.ArcGIS.Client.Extensibility.WindowType)'.
[ATTACH=CONFIG]34238[/ATTACH]
Regards,
Hani
tarmiziabd_rahim
New Contributor II
HaniDraidi
Tarmizi, sorry for the late reply. I tried the tool and I got this error:
"Error 0x17F8.  Debugging resource strings are unavailable. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.30514.0&File=mscorrc.dll&Key=0x17F8"
TracyMusil
Hani,
        Did you have any luck getting the GoToCoordinate Tool to work in Arcgis Viewer 3.2? I am searching for an updated version but can't seem to find one out there. Every time I try to launch the tool I get the following error: "Method not found: 'Void ESRI.ArcGIS.Client.Extensibility.MapApplication.ShowWindow(System.String, System.Windows.FrameworkElement, Boolean, System.EventHandler`1<System.ComponentModel.CancelEventArgs>, System.EventHandler, ESRI.ArcGIS.Client.Extensibility.WindowType)'
Thanks!
Tracy
HaniDraidi
Hi Tracy,
Till now I couldn't make it run, please keep us posted if you found a solution.
