Hi, I've came across a problem with Filter Layer function on secured services. When I try to use Filter window on a secured layer the form stays blank: [ATTACH=CONFIG]25917[/ATTACH] I listened to the network communication and found out following: When aplication is loaded, it opens the login form and user enters credentials. After that, layer is initialized using token: http://SERVER/arcgis/rest/services/SERVICE/FeatureServer/0?f=json&token=7gcVolwT3rhHHCUCYhvArF3PWbnA... Query request for getting data also contains token. But when Filter Layer window is opened the service is called without token: http://SERVER/arcgis/rest/services/SERVICE/FeatureServer/0?f=json so the server returns an error: [HTML]{"error":{"code":499,"message":"Token Required","details":[]}}[/HTML]
In Application builder an error is displayed after closing this blank Filter window: [ATTACH=CONFIG]25918[/ATTACH]
I made tests on two independent servers and different data and both resulted in same error. Thereby I suppose that this is an bug. Can anyone from Esri confirm and resolve this?
I contacted our local Esri distributor and they confirmed that this is a bug reported as #NIM091132: Filter tool in Silverlight Viewer 3.1 does not work on Secured Services for ArcGIS Server 10.1.1. The error is showed in detail here.
