Modify Silverlight Viewer Editing Popop
3485
09-29-2014 10:39 PM
HenryKo
New Contributor III
There is a ESRI Silverlight application built with ArcGIS Viewer for Silverlight 3.2. I want to modify the out-of-box popup for editing (when editing features in a feature service) so that it is wider, and it can wrap around fields that are too long. At the moment the out-of-box popup for editing does not text-wrap so fields with long names look terrible.
How do I do that?
Can I modify the style for the editing popup in one of the XAML files?
Or do I need to build a custom Silverlight Add-in to do that?
TimothyHales
Esri Notable Contributor
I've moved your post into the ArcGIS Viewer for Silverlight space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
