Positioning a TextBox or <esri:InfoWindow>
698
08-01-2013 08:09 AM
YurongTan
I am working on a secondary "popup" from a MapTip to display additional information and I haven't been able to position the pop up (either TextBox or esri:InfoWindow) properply.  In fact the pop up stays at the center of the map display.  Is there a pointer out there or a sample to look at?  Thanks
PietaSwanepoel2
Do you refer to this InfoWindow?
http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#InfoWindowSimple
http://resources.arcgis.com/en/help/silverlight-api/apiref/api_start.htm
You would need some form of mouse-event handler to change the anchor point of the InfoWindow, eg. MouseLeftButtonDown and MouseLeftButtonUp
YurongTan
Thank you!  I was first trying to use the InfoWindow and realized that it is not that flexible as the DataTemplate must have a fixed items (or lengths).  Is there a way to programatically (C#) customize the DatTemplate and then bind/attach it to the InfoWindow?  My problem is that I have a point feature layer and each point can have as many as 35 different measurements (some have a few only).  In addition, I would like to color-code (red, green, yellow, etc.) the measurements based on their values for high, warning, and normal.  Any pointers on this?  Thanks
PietaSwanepoel2
Sounds like the easiest solution would be to have tool that contains a datagrid that you can minipulate eg. values. colours, etc
You will act on a click event , find the results and present it to the client as you want
