Hi all,
I just downloaded the available source code for the MeasureTool in an effort to change a few settings (give the decimal degrees more places past the decimal point for the point tool)...and when I try to compile (Using VS 2010 with the prerequisites, I get the following:
Exception was thrown on "Setter": Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
Any ideas? Adam
at MS.Internal.XcpImports.MethodEx(IntPtr ptr, String name, CValue[] cvData)
at MS.Internal.XcpImports.MethodPack(IntPtr objectPtr, String methodName, Object[] rawData)
at MS.Internal.XcpImports.Collection_Add(PresentationFrameworkCollection`1 collection, Object value)
at System.Windows.PresentationFrameworkCollection`1.AddImpl(Object value)
at System.Windows.PresentationFrameworkCollection`1.System.Collections.IList.Add(Object value)
at Microsoft.Expression.DesignModel.InstanceBuilders.ClrObjectInstanceBuilder.InstantiateChildren(IInstanceBuilderContext context, ViewNode viewNode, DocumentCompositeNode compositeNode, Boolean isNewInstance)
