Currently, the query widget will identify it has x/xx results upon first return. Example, 124 of 236. The user will then need to compare those numbers to ensure that when they export the list, it will contain all of the expected results. ESRI has incorporated the "Load More" button get around this issue.
I would like to suggest that when the export function is selected, the widget automatically exports all of the results. I can't think of a use case where the user would only want some of the expected results.
