All,
Where would I add mapservice/featurelayer urls to load on startup in WAB Developer Edition 2.5/2.7? I've tried to alter the MapManager.js/utils.js files(_show2DWebMap, _createWebMapRaw, createWebMap) but I assume it needs the portal Url, webmapid, etc.. I can manually place an id(from AGOL) in the config after creating an app and create a custom widget that when clicked can load the layers onto the map. However, I would like by default when I create apps in WAB Dev Ed to load my custom basemap without using a map id from AGOL. Also, for specific apps I need layers loaded onto that map(layers vary). I have done this using JS API 3.x but would like to incorporate into WAB. Any ideas? Thanks in advance!
