I am having trouble adding a custom parameter ( not a customtextelement) to the WAB print widget.
I have added
To my arcpy script, and published it. However when i load the script as the path in the WAB 2.4 print widget, i get
And the user cannot set the new parameter value.
The ?json response of the script does include the parameter, so i can't figure out why it doesnt display. It also does not display in the WAB print widget config dialog
{ "name": "Script", "displayName": "Script", "description": "print test", "category": "", "helpUrl": "http://www.mymanatee.org/arcgis02/rest/directories/arcgisoutput/printing/Script_GPServer/printing_Script/Script.htm", "executionType": "esriExecutionTypeSynchronous", "parameters": [ { "name": "Web_Map_as_JSON", "dataType": "GPString", "displayName": "Web_Map_as_JSON", "description": "print test", "direction": "esriGPParameterDirectionInput", "defaultValue": " ", "parameterType": "esriGPParameterTypeRequired", "category": "" }, { "name": "Format", "dataType": "GPString", "displayName": "Format", "description": "format", "direction": "esriGPParameterDirectionInput", "defaultValue": "", "parameterType": "esriGPParameterTypeOptional", "category": "", "choiceList": [] }, { "name": "Layout_Template", "dataType": "GPString", "displayName": "Layout_Template", "description": "layout", "direction": "esriGPParameterDirectionInput", "defaultValue": "staffmap", "parameterType": "esriGPParameterTypeRequired", "category": "", "choiceList": [ "staffmap" ] }, { "name": "Output_File", "dataType": "GPDataFile", "displayName": "Output_File", "description": "print test", "direction": "esriGPParameterDirectionOutput", "defaultValue": null, "parameterType": "esriGPParameterTypeRequired", "category": "" }, { "name": "Include_Attributes", "dataType": "GPString", "displayName": "Include_Attributes", "description": "include_Attributes", "direction": "esriGPParameterDirectionInput", "defaultValue": "False", "parameterType": "esriGPParameterTypeRequired", "category": "", "choiceList": [ "True", "False" ] } ] }
Any Help would be appreciated.
