I am trying to configure a simple search, and I'm sure there's a way to do this, but I can't figure it out with the Finder App or any others.
My goal is to perform a search by address, and then instead of a popup with that address, I'd like for the intersecting feature info to automatically pop up. One place I'm trying to achieve this is with a water basin HUC shapefile. So, if someone enters an address, there will be a popup with a couple of fields (Basin Name, HUC8 Number).
Right now, the search zooms into the address. Of course, loading the feature takes a bit, and then the person would have to click on the screen (the features are orders of magnitude larger than address parcels) to get feature info to pop up.
Ideally, I'd like to allow people to directly search for the basin name out of the same search bar. If the search cannot be configured how I want, this would at least make it clearer to click on the feature to get a popup with info.
I'd also like to tweak the scale to which the zoom occurs when a search is performed. Right now, it's overkill.
