Cannot open any webmap item through webappviewer
257
03-26-2020 12:37 PM
DávidGregor
New Contributor II
 I'm following this: Web AppBuilder for ArcGIS: Customizing and Extending - YouTube   video, provided by esri.
wab 2.15. - I tought it's because of the certificate error, but after providing cert, the problem remains. I can open this webmap in the webappbuilder.
With this conf.(section):
 "portalUrl": "https://hostname.local/portal",
  "appId": "",
  "authorizedCrossOriginDomains": [],
"map": {
    "3D": false,
    "2D": true,
    "position": {
        "left": 0,
        "top": 0,
        "right": 0,
       "bottom": 0
"itemId": "43bjh424bkb5353",
"mapOptions": {},
"id": "map",
Writing this into browser:
https://hostname.local:3344/webappviewer/?config=configs/config.json
I get this error:
init.js:115 TypeError: Cannot read property 'itemId' of undefined
at Object._show2DWebMap (MapManager.js?wab_dv=2.15:277)
at Object._showMap (MapManager.js?wab_dv=2.15:93)
at Object.showMap (MapManager.js?wab_dv=2.15:78)
at Object._loadMap (LayoutManager.js?wab_dv=2.15:150)
at Object.<anonymous> (LayoutManager.js?wab_dv=2.15:108)
at init.js:64
at m (init.js:108)
at e.then.b.then (init.js:111)
at Object.<anonymous> (LayoutManager.js?wab_dv=2.15:104)
at init.js:64 "TypeError: Cannot read property 'itemId' of undefined
at Object._show2DWebMap (https://hostname.local:3344/webappviewer/jimu.js/MapManager.js?wab_dv=2.15:277:46)
at Object._showMap (https://hostname.local:3344/webappviewer/jimu.js/MapManager.js?wab_dv=2.15:93:18)
at Object.showMap (https://hostname.local:3344/webappviewer/jimu.js/MapManager.js?wab_dv=2.15:78:14)
at Object._loadMap (https://hostname.local:3344/webappviewer/jimu.js/LayoutManager.js?wab_dv=2.15:150:23)
at Object.<anonymous> (https://hostname.local:3344/webappviewer/jimu.js/LayoutManager.js?wab_dv=2.15:108:18)
at https://js.arcgis.com/3.31/init.js:64:337
at m (https://js.arcgis.com/3.31/init.js:108:248)
at e.then.b.then (https://js.arcgis.com/3.31/init.js:111:132)
at Object.<anonymous> (https://hostname.local:3344/webappviewer/jimu.js/LayoutManager.js?wab_dv=2.15:104:12)
rejected at a (https://js.arcgis.com/3.31/init.js:109:154)
at m (https://js.arcgis.com/3.31/init.js:108:407)
at k (https://js.arcgis.com/3.31/init.js:108:174)
at e.resolve (https://js.arcgis.com/3.31/init.js:110:267)
at Object.<anonymous> (https://hostname.local:3344/webappviewer/jimu.js/LayoutManager.js?wab_dv=2.15:132:13)
Error
at e.then.b.then (https://js.arcgis.com/3.31/init.js:111:77)
at ja (https://js.arcgis.com/3.31/init.js:28:441)
at https://js.arcgis.com/3.31/init.js:29:186"
