Hello;
I would like to know if is possible to change the ESRI logo image in the print template of the Directions dijit included in the WAB Directions Widget, by other image.
I have tried to get the img HTML element through its css class and change the src property but the variable is empty because i think that the directions diit and the print template are different HTMLs.
You can see a example in:
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=widget_directions_basic .
The print button is displayed after calculating a route.
You can see the logo in the attached file.
Best regards
