change on-screen icon size
6237
19
01-22-2016 09:57 AM
DaveOrlando
Occasional Contributor III
hello,
I'm sure the developers are probably tired of us mucking in their code, but I really want to make my on-screen icons bigger.
I found where to change the size of the image within the icon, but not the icon itself, it gets overwritten from the 'Inline style'
this is in ~\jimu.js\css\jimu.css
/*css for PreloadWidgetIcon dijit*/
.jimu-widget-onscreen-icon{
  width: 105px; /*added*/
  height: 105px; /*added*/
  position: absolute;
  cursor: pointer;
  border-radius: 4px;
.jimu-widget-onscreen-icon img{
  width: 80px; /*changed*/
  height: 80px; /*changed*/
  margin: 10px;
if there is some easy code to change, please let me know, thanks.
RobertScheitlin__GISP
Dave,
  The hard coding of the 40px comes from the LayoutMnager.js in the jimu folder (see line 21-24):
_createPreloadWidgetIcon: function(widgetConfig){
      var iconDijit = new OnScreenWidgetIcon({
        panelManager: this.panelManager,
        widgetManager: this.widgetManager,
        widgetConfig: widgetConfig,
        configId: widgetConfig.id,
        map: this.map
      if(widgetConfig.position.relativeTo === 'map'){
        html.place(iconDijit.domNode, this.mapId);
      }else{
        html.place(iconDijit.domNode, this.id);
      //icon position doesn't use width/height in config
      html.setStyle(iconDijit.domNode, utils.getPositionStyle({
        top: widgetConfig.position.top,
        left: widgetConfig.position.left,
        right: widgetConfig.position.right,
        bottom: widgetConfig.position.bottom,
        /*width: 40,
        height: 40*/
        width: 105,
        height: 105
      iconDijit.startup();
      if(!this.openAtStartWidget && widgetConfig.openAtStart){
        iconDijit.switchToOpen();
        this.openAtStartWidget = widgetConfig.name;
      this.preloadWidgetIcons.push(iconDijit);
      return iconDijit;
Dave,
        map: this.map
      }else{
        /*width: 40,
        height: 40*/
        width: 105,
        height: 105
      return iconDijit;
DaveOrlando
Thanks a million, I should have seen that.
here are the four steps I took to enlarge the icon, enlarge the image within, move one over, and change the panels open position.
by Anonymous User
Not applicable
Does this still work? I'm having no luck adjusting the size of the placeholders
Eoin,
   No files have changed since then. Here are the steps and files for WAB 2.4: (if just enlarging them x2)
  • This is for image inside of icon
    • jimu.js/css/jimu.css
    • .jimu-widget-onscreen-icon img{
        width: 40px;
        height: 40px;
        margin: 20px;
  • This is for the icon itself
    • jimu.js/LayoutManager.js
    • lines 695, 696, 728 and 729
      • adjust width and height to 80.
  • This is to move the second and third icons over
    • Main config.json
      • Change left to 145 and 235 to the second and third
  • This is to change widget panel opening location
    • jimu.js/OnScreenWidgetPanel.js
      • _getPositionInfo function lines 324 and 328
        • Change 40 to 80
by Anonymous User
Not applicable
Thank you for you help Robert, I wasn't seeing any changes within WAB because I was editing files in the stemapp folder rather than the specific app folder, silly mistake I know!
GeorgeKatsambas
Where in the main cofig.json is the change 'left" ?
In the widgetOnScreen array the widgets objects that have a placeholderIndex property.
CCWeedcontrol
I am having trouble making the onscreen-icon image bigger. I am on WAB 2.4.
I am editing the \server\apps\6\jimu.js\css at lines but my icons are not bigger, what i am doing wrong?
I made changes to the LayoutManger.js and that worked fine.
  position: absolute;
  cursor: pointer;
  border-radius: 4px;
  width: 40px; /*changed from 20 to 40*/
  height: 40px; /*changed from 20 to 40*/
  margin: 10px;
I am not sure what you are missing. I don't think I can explain or outline it any further. Make sure you are changing the files for the app you are working in.
