Ok, I completed a cool application using the WebApp Builder for ArcGIS.
Everything was going smoothly until I followed the Deploy the app instructions.
I did as directed below.
On step 3 I went to register but it said it was already registered. So thought I needed to re-register to make it work. So I unregistered and re-registered now... getting a new appid and app secret. What is app secret?
Anyway, I opened the config.json and put in the app id.
Now I have two problems.
1) The map opens fine from my unzipped folder on my server however neither the legend nor the layers list will show up. It just spins hour glass.
2) Now when I start Web AppBuilder my APP that I spent days creating to perfection does not load. I see there is an upload button but I don't see any help on how to upload. Can I upload the app I unzipped to my folder that I just downloaded?
Please help, or if there is someone here that would have a few minutes to connect to my PC and help me figure out what happened?
Adam
Adam,
I am glad you got your app all worked out. Can you go ahead and mark this as answered? On any of my replies you will find a "Correct Answer" link that you can click
You can also mark replies as helpful in GetNet by finding the "Actions" menu link at the bottom of a reply and choose "Mark as Helpful"
Both of these actions help the community to find the answer and helpful replies, beside giving me points for spending time with you on this question.
Thanks for the help!
I was able to mark all as helpful. I didn’t see the correct answer option.
Adam Olson
Natural Resource GIS Specialist
Itasca County Land Department
1177 LaPrairie Ave.
Grand Rapids, MN 55744
(218) 327-7309 direct tel
(218) 327-4160 fax
Adam,
It should look like this
And be on every reply other than your original post (it is not on the actions menu but above it).
Ok now it showed up after I reaccessed it. Thanks for the help.
