Configuring pop-up window
1178
02-09-2017 01:13 AM
AveKargaja
I wonder if it possible to configure the layer info pop-up window to show attribute data from several layers on a single view, so that the end user does not have to switch with those left-right arrows between different objects from different layers.
By the way, I'm using WAB dev.edition 2.3 and my map layers are configured via LocalLayer widget.
RobertScheitlin__GISP
Ramon,
   No there is no existing configuration for making the popup show data from several layers. That is actually what the Identify Widget is designed for.
https://community.esri.com/docs/DOC-3250
Ramon,
AveKargaja
Thanks, I'll take a look if this kind of approach satisfies my needs.
