Custom Filter Widget
4083
02-11-2015 09:36 AM
AliciaCarnell_Wiltz
New Contributor III
Hi Robert,
I wanted to know if you would be able to supply me with any help on a custom filter widget? Thanks
RobertScheitlin__GISP
Alicia,
  I branched this question to a new thread as it is not proper forum etiquette to hijack a thread with a separate question that has nothing to do with the OPs question.
So can you provide more detail about your question?
AliciaCarnell_Wiltz
New Contributor III
Oh sorry about that. I thought it was sending a message directly to you. I saw a discussion about interactive filter widgets and I was interested in using that as well and wanted to know if you know anything about this type of widget for webappbuilder. We are in need of a new crime map application that has the ability to check on and off crimes based on date and precinct. Thanks
Alicia,
   Currently there is the OTB Query widget in WAB and then there is my Enhanced Search widget. Those are the only currently available options.
Query widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Enhanced Search Widget Version 1.1.0.3
AliciaCarnell_Wiltz
New Contributor III
ok thanks I will look into it.
