Does WAB Developer Edition Support Single House with Subaddress Locator Style?
3332
5
06-02-2016 12:39 PM
GabiVoicu
The same exact geocoding service is working just fine when using the WAB online but it does not seem to work the same when the developer edition is used - sub-addresses don't seem to work ...
I would appreciate any insight on this topic
Thank you
GabiVoicu
Based on technical support from ESRI in order to make our 10.3
geocoding service work on any sub address with unit number (apartment) we had
to delete some lines of code in the widget.js file within the search (widget)
folder inside the widgets folder of the Web AppBuider application:
Server->apps->appID->widgets->Search->Widget.js
Line number 252: delete the localSearchOptions and the comma
after the ….searchInCurrentMapExtent
RobertScheitlin__GISP
Gabi,
  Can you share a screen shot of your browsers web console error if there is one?
GabiVoicu1
New Contributor III
Robert thank you so very much for reading my post and taking the time to ask me for more details - really appreciate your time.
I'm inserting here screen shots with the same exact address searched on three different ways - using the same geocoding service (not externally accessible)
- one is the WAB dev edition
- one is the online version of the WAB
-  and the third is the rest interface of the geocoding service used
All work except the WAB dev edition and that is the only one that also throws errors on the console - also inserted here - but it seems like the errors are there no matter if geocoding returns or not any matching results (they show up even when matching results are found and retrieved....)geocodingWAB_dev.pnggeocodingWAB_online.pnggeocodingRest.pnggeoWAB-dev_errors.png
Gabi,
  Sorry there is just not enough info here for me to go on. Is there anything else in the web console that could help me diagnose?
GabiVoicu
I know Robert - I wish the geocoding service was externally accessible. I really appreciate your time ....
I just opened a case with ESRI and they are trying right now to reproduce the issue - will let you know of our findings on this.
We love your widgets - great work !
Thank you
GabiVoicu
