Dojo/query and Webappbuilder layerlist widget (LayerListView.js)
2657
06-04-2015 10:46 AM
TimJacobsen
New Contributor III
I'm trying to modify LayerListView.js of the webappbuilder layer list widget, so the image of the noLegend-image class will change based on the layer.
To accomplish this I tried adding the else-if to the dojo query below.  Based on the HTML/CSS in the attachment, how should the else-if be filled to populate the img class based on the tr class value.  Maybe this is the wrong approach but it seems the most obvious.
Dojo Query:
var imageName:
if (layerInfo.isTable){
     imageName = 'images/table.png';
else if query () == 'yourLayer' {
     imageName = 'images/yourLayer.png';
else {
     imageName = 'imageName = 'images/noLegend.png';
Tags (1)
RobertScheitlin__GISP
Tim,
  Unless I am misinterpreting the code and your intent then what you are asking is not doable. You are asking for the proper code to query an attribute of a element that is yet to be created and added to the DOM.  I think this is what you are after:
      var imageName;
      if (layerInfo.isTable) {
      } else if (layerInfo.id === 'yourlayer'){
      } else {
Tim,
      var imageName;
      } else {
TimJacobsen
New Contributor III
That was it, thanks!
