DojoRequest in Web app builder
1974
17
12-11-2017 02:11 PM
VenkataSrikanth_Dasari
I am requesting an image in the Dojo Request and it is appending ?wab_dv=2.6 in the url and failed to query in the custom widget..
Tags (1)
RobertScheitlin__GISP
Srikanth,
  You just need to educate the client that running WAB Dev is good for development purposes but when development is done the app needs to downloaded and deployed to web server for production and then proxy.js is no longer an issue and the proxy.ashx will be used just like you have.
Robert,
Client Environment is up and running... we can't change in the current situation...End users are using the application..
Any workaround for the above query...
Cheers,
Srikanth Dasari
I don’t know of a way to resolve the access issue then. What is boils down to is the client is not using the environment as it is intended and you as the consultant/developer need to make them understand.
JunshanLiu
Occasional Contributor III
There is http proxy config in app config, have you tried this?
https://developers.arcgis.com/web-appbuilder/api-reference/app-configuration.htm
Junshan Liu
Esri R&D Center Beijing
19th Floor, Phoenix Place Office Tower A, 5A Shuguang Xili
Chaoyang District | Beijing 100028 | China
T (86 10) 57302700
junshan_liu@esri.com<mailto:junshan_liu@esri.com> | esri.com
The Science of Where
Thriving in China, Empowering the World
发件人: srikanth dasari venkata
发送时间: Thursday, December 14, 2017 5:47 AM
收件人: Junshan Liu <junshan_liu@esri.com>
主题: Re: - Re: DojoRequest in Web app builder
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from srikanth dasari venkata<https://community.esri.com/people/sri_kanth0526?et=watches.email.thread> in Web AppBuilder for ArcGIS - View the full discussion<https://community.esri.com/message/736015-re-dojorequest-in-web-app-builder?commentID=736015&et=watches.email.thread#comment-736015>
I will try and let you know and it seems it will work..
Hope for the best...
Thanks Robert and Junshan Liu for the help.
JunshanLiu
I agree with you Robert. How about set the deployVersion = “” if your widget wants to disable this feature?
Junshan Liu
T (86 10) 57302700
发件人: Robert Scheitlin, GISP
发送时间: Tuesday, December 12, 2017 7:53 PM
reply from Robert Scheitlin, GISP<https://community.esri.com/people/rscheitlin?et=watches.email.thread> in Web AppBuilder for ArcGIS - View the full discussion<https://community.esri.com/message/735630-re-dojorequest-in-web-app-builder?commentID=735630&et=watches.email.thread#comment-735630>
JunshanLiu
Can you modify this function appendDeployVersion in env.js?
I am not in the client location since beginning and someone else setup the environment...
Cheers,
Srikanth Dasari
