Hello,
Is there any method to export the map layers in the WAB to KMZ other than using the Extract Data tool in the Analysis widget?
I am trying to figure out a method that lets me export my map to KMZ file but not using the “Extract Data” esri out of the box tool.
The reason on this:
- 1- The Extract tool doesn’t work with any feature layer, the layer should be a hosted feature layer. In my case I want to export features from a service hosted in my ArcGIS server.
- 2- I want this tool to be available for all of my app users regardless the permissions/ levels.
I am thinking of using a geoprocessing service that uses the “Map to KML” tool in the arcmap, but the main issue it that this tool takes an MXD as an input and I think it will not work on the app builder.
Thanks a lot,
