Go to XY widget in Web App Builder
10984
12
10-30-2015 07:16 AM
ClarkLangridge
Occasional Contributor II
Why is there no Go To XY widget included in the set for Web App Builder?  Most of our staff work in the back country where there is no civic address (or in some cases, even a road).  When they get back to the office, the only way to figure out where they were is to hover the mouse over the map and move it around until the display coordinates match what they recorded on their handheld GPS.
KyleBalke__GISP
Occasional Contributor III
Clark,
You can zoom/center a map in a Web AppBuilder application using x,y coordinates.. Just add &center=x,y to the end of the URL for the application.
Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
You can also enter an X,Y coordinate pair into the Find address or place search box to do the same as above.
And another option, use the GeoLookup widget (currently in Beta) to drag a CSV containing the lat/long onto the application and plot the points.
GeoLookup widget—Web AppBuilder for ArcGIS | ArcGIS
Kyle
ClarkLangridge
So I either have to explain to my (very) non-technical users how to modify a url in this very particular way or how to create a .CSV file and import it in to the app?
OR ESRI could include a commonly used tool in GIS in their web app builder widgets (and I've had ESRI technical support people say the same thing).  I know which solution I prefer.
ClarkLangridge
And I am probably just being snippy about this, but I find it immensely frustrating that people have to find these sorts of work-arounds for something that should be common sense.
KyleBalke__GISP
What about the option to enter the X,Y in the Find address or place?  That seems to be the easiest solution given your description of the technical acumen of your users  It is also likely much faster the poking around on the map to find their location.
ClarkLangridge
We tried that: doesn't work.
Tried every variation I know of how to feed in a lat and long, with similar results.
KyleBalke__GISP
Longitude first (x coordinate value) then a comma and then the latitude (y coordinate value).  I used your coordinate pair following that standard and it worked (see the image).
ClarkLangridge
Doesn't work for me.  How is your  service set up.
Plus, your result seems to be suggesting that it wants lat and long, not long and lat.
KyleBalke__GISP
Try refreshing your browser and then try it again.
JackZHANG
Search Lon,Lat in the search widget works, but make sure you have a Geocoder like ESRI World Geocoder enabled.
