Help With Webapp Builder
1019
10-06-2016 10:22 AM
CadAssistant_3
I have a set of points on a layer and I want customers to be able to click a point and be able to edit some fields in the pop-up. I know how to do this on the online map maker but I can't seem to figure it out in the Web App builder. Any help would be appreciated, thank you.
RobertScheitlin__GISP
Cad Assistant 3,
   You add the edit widget to your app and as long as the layer has a FeatureService available for it then you will be able to edit it's attributes.
Cad Assistant 3,
CadAssistant_3
Thank you Robert!
Cad Assistant 3,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
