Interaction with widgets
2777
08-19-2015 06:59 AM
BrianRassier
I'm just starting to get a feel for Web AppBuilder.  When creating custom widgets, what level of interaction is expected with existing "out of the box" widgets?  For example, if my widget wants to select a specific item in the AttributeTable widget, there doesn't seem to be a great API for something like that.  Is that accurate or am I missing something?  If this type of interaction would be required, is the expectation that developers would extend the existing widgets and build this functionality themselves?
Thanks
-Brian
Tags (1)
RobertScheitlin__GISP
Brian,
  As you have probably already noticed there is no exposed methods or event listeners for selecting a row in the Attribute Table widget so yes your only option would be to extend the widget to allow for this. Hopefully in the future there will be something you can publish to select certain rows of certain tables. The only way you are going to see these sort of things added to WAB though is for you to call tech support and log an enhancement request.
Brian,
BrianRassier
Thanks for confirming my hunch Robert.  I appreciate it!
