Is there an easy way to edit multiple feature layers with an edit widget session?
2798
10-01-2015 05:00 AM
jamesmullen
Is there an easy way to edit multiple feature layers with an edit widget session?  I want to edit two different line type elements that I want to have the same geometry. (Conduit and Fiber in the same trench.)
RobertScheitlin__GISP
James,
   Currently no. You can make an enhancement request by calling tech support or adding this on the ideas site.
SethLewis1
Occasional Contributor III
If you're using WAB Developer Edition you may want to look into the Batch Attribute Editor.
solutions-webappbuilder-widgets/BatchAttributeEditor at master · Esri/solutions-webappbuilder-widget...
DerekLaw
Esri Esteemed Contributor
FYI, the Batch Attribute Editor widget is tentatively planned to be added into core Web AppBuilder for the next release.
Hope this helps,
StuartGrey1
New Contributor III
Please make this happen, pretty please
