Issue Adding Attachment to related table
795
5
06-11-2018 10:59 AM
AndresCastillo
MVP Regular Contributor
I can't add attachments to a related table record.
I click add, browse for file, add.....but nothing gets added.
I have no issues adding the attachments in arcmap 10.4.1
The structure is as follows:
·         FC
·         related to
·         Inspection History Table
·         via Parent Global ID, Global ID Data Type/Child Guid, Guid Data Type
·         relate to
·         Attachment table
These are published as a feature access service using ArcGIS server 10.4.1.
The service is added to an AGOL web map.
The web map is consumed in a WAB DE 2.8 app.
AndresCastillo
Robert Scheitlin, GISP Champion
Do you have any tips?
RobertScheitlin__GISP
Andres,
   I don't have any experience trying to add an attachment to a related record. Your best bet would be to contact esri tech support.
AndresCastillo
Thank you Robert.
AndresCastillo
I get a 504 error.
See the attached image for the capture from Fiddler:
Furthermore, the response TextView states:
[Fiddler] ReadResponse() failed: The server did not return a complete response for this request. Server returned 0 bytes.
AndresCastillo
I am able to add the attachment on AGOL WAB, then open it.
Yet, when I try to open the same attachment on arcmap, it doesn't open.
