I installed WAB DE 2.11 along with the LocalLayer Widget (version 2.5). I seem to have no issues building an app, except when I go Launch and then this is what happens:
1) If I Launch it in IE 10, IE 11, or Chrome, the map appears in a separate tab, shows but does not get any further with the launch icon (those bars you see when you first launch an app, its right after the map appears that the launch icon keeps spinning and spinning and spinning) in the map window keep spinning. I am using HTTP, not HTTPS. I do not have an HTTPS site (not yet anyway, will soon). The app works good in FireFoxx except for item #2 below.
2) In FireFox, after I launch the app, I click on the LayerList and Legend icons (upper right corner of the Map Window) and nothing happens. I should click on them and they expand showing the Layers I added. Is this a bug with 2.11? When I go into theWidgets Panel and check the LayerList Widget, I see all the default boxes checked, and the "Choose Which Layers Will Be Shown On The List" box as empty. Should the Layers I added to the app be showing here?
Could this be an issue with me using the LocalLayer Widget 2.5? (2.5 seems to be the most recent LL version)
Any assistance will be appreciated.
thanks,
Tim
