Layers missing in some widgets
1745
11
03-05-2018 07:27 AM
PabloIzquierdo1
New Contributor III
Hi all,
Suddenly my layers don't appear in the select, attribute table and screening widgets, anyone is having the same issue, it is a bug or there is a new update of the WAB on the way?
Pablo
PabloIzquierdo1
New Contributor III
Hi Robert, it might help you in the future, the problem was a layer in the layer list without the query capabilities activated.
RobertScheitlin__GISP
Pablo,
   I have not seen any issue like that.
PabloIzquierdo1
New Contributor III
It is weird, I deleted the select widget and add it again, still the layers doesn't appear, but in the setup wizard I can see them.
What happen if you start a new app?
PabloIzquierdo1
New Contributor III
If I chose a different web map works, but with the same one, still doesn't load the layers in the widgets
Pablo,
  Have you restarted the map service(s) that contain the data that the web map uses?
PabloIzquierdo1
New Contributor III
Nothing, it keeps trying to load the layers as below
Attribute table widget keeps loading layers
Can you send a screenshot of your browsers web console error(s)?
PabloIzquierdo1
New Contributor III
Weird, there aren't errors
I am out of ideas then
