Hi Barnaby,
Thanks for the reply. Yes I did set it up using those instructions, (the first part, putting in the widget definition for the foldable theme, I figured the rest of the directions is to get the other widgets/themes to work with it). I’ve double and triple checked it and all looks OK. However, I’m not sure where to find it, should it show up in the widget list when I click one of the numbered “placeholders”, or is it in the header controller widgets, or am I looking in the wrong places? (I’m kinda new to all this…)
This is what I added to the widgetonscreen section of the config.json
"uri": "widgets/LocalLayer/Widget",
"visible": false
And I made sure the LocalLayer is the same as the folder name for the widget that I downloaded from github (I changed it from LocalLayer-2.2)
And I am using the Foldable theme
I did notice that after I create the app, when I go to the widgets folder under server for the app that I created, the LocalLayer folder shows up there, so it is finding it and copying it over when the app is created.
