LocalLayer widget and WAB 2.3
3298
28
03-24-2017 03:33 PM
ReneeGerasimtchouk
Does the LocalLayer widget work with WAB 2.3? I configured it and can add layers but the OK, Cancel, and X button do not do anything - when clicked on, nothing happens.
Thank you,
Renee
BarnabyRockwell
Excellent!  Good to know.  I always make local backups of old WAB Dev versions just in case...
RajuGopinath
Barnaby- How you changed the default base map to something other than arcgis.com map? I am trying to create default basemap by adding the following lines to config file after taking out the "itemId": "6e03e8c26aad4b9c92a87c1063ddb0e3"
"basemaps": [
                "label": "Charlotte County Aerials",
                "url": "http://<myserver>/arcgis/rest/services/Aerials/Aerials2014/MapServer",
                "type": "tiled",
                "visible": true
                "url": "http://<myserver>/arcgis/rest/services/Labels/Imagery_Labels/MapServer",
                "type": "tiled",
                "visible": true
But it's still showing arcgis.com topo map. This creates an issue with my layers in basemap gallery due to spatial reference conflicts. Any thoughts?
BarnabyRockwell
I made a custom, public AGOL Web Map that includes the esri Imagery basemap.  Then I set the app to call that Web Map.
I typically use Robert's Enhanced Basemap Widget to switch basemaps.
RajuGopinath
Oh ok- that won't work for me as I need to completely localize the app without any dependency to arcgis.com
JeffSauder
I did what Ron suggested and it was in a nested folder, I fixed that and now it works.  Thank you Ron and Barnaby for looking at this with me.  However, I am now having the issue that the others are having here so I'll stay tuned...
RonSteward
I have the same problem Renee describes.
Here is an error shown in Chrome dev tools from trying to close the configuration window.
"Cannot read property  '_tables' of undefined"
LocalLayers Error
RajuGopinath
Yes, I am having the same issue which Ron pointed out- "Cannot read property  '_tables' of undefined". Any pointers?
BarnabyRockwell
BTW, the regular GeoNet thread for the LocalLayer widget is:
LocalLayerWidget and AccessifizrWidget | GeoNet
GisGKAuckland
I too didn't have much luck with these two set of components.
I assume either they don't have backward compatibility or the setup instructions is missing one or more steps
