Modifying WAB based app "Sign In" window
2018
5
01-25-2017 06:32 AM
AveKargaja
Hi
Where can I modify the text content of WAB based app "Sign In" window? My focus is on the service (subfolder/service) and server (http://...) name, which I want to be removed (or hidden).
NLS libraries are not very helpful with those
sign in window
RobertScheitlin__GISP
Ramon,
   This is what I figured out. In the jimu.js/tokenUtils.js find the _bindEvents and add lines 28-31 and add the new requires lines 18 - 20 and 23.
define([
  'dojo/_base/lang',
  'dojo/_base/array',
  'dojo/aspect',
  'dojo/Deferred',
  'dojo/cookie',
  'dojo/json',
  'dojo/topic',
  'dojo/request/script',
  'esri/kernel',
  'esri/config',
  'esri/request',
  'esri/urlUtils',
  'esri/IdentityManager',
  'esri/arcgis/OAuthInfo',
  'jimu/portalUrlUtils',
  'jimu/utils',
  'dojo/on',
  'dojo/dom-style',
  'dojo/query'
function(lang, array, aspect, Deferred, cookie, json, topic, dojoScript, esriNS, esriConfig,
  esriRequest, esriUrlUtils, IdentityManager, OAuthInfo, portalUrlUtils, jimuUtils, on, domStyle, query) {
    _bindEvents: function(){
      on(esriNS.id, 'dialog-create', function(){
        domStyle.set(query(".serverLink", esriNS.id.dialog.domNode)[0], "display", "none");
        domStyle.set(query(".resLink", esriNS.id.dialog.domNode)[0], "display", "none");
Ramon,
define([
  'dojo/_base/lang',
  'dojo/_base/array',
  'dojo/aspect',
  'dojo/Deferred',
  'dojo/cookie',
  'dojo/json',
  'dojo/topic',
  'esri/kernel',
  'esri/config',
  'esri/request',
  'esri/urlUtils',
  'jimu/utils',
  'dojo/on',
  'dojo/dom-style',
  'dojo/query'
AveKargaja
Works just the way I expected, thanks a lot
AveKargaja
Oh, by the way Robert Scheitlin, GISP‌, do you have a clue where the rest of the sign in window text comes from. Trying to figure this out as this also looks kind of clumsy with my native language package  In english it is just one string, but in my case consists of three different strings.
Ramon,
   Sure you need to change the default strings associated with the API and the dijit:
'dojo/i18n!esri/nls/jsapi',
esriBundle
esriBundle.identity.info = "Please sign in to access the item on ${server} ${resource}";
Make sure you see this thread for info:
https://community.esri.com/thread/165417
AveKargaja
Thanks once again
